Creating detail callouts
Tool |
Tool set |
Detail Callout
Dims/Notes |
Use the Detail Callout tool to mark an area on the drawing and indicate the location of the detail drawing for it.
In Design Suite products, a detail callout can be linked to a viewport. If the callout was used to create the viewport it's linked to, it also "defines" the viewport, which means that moving or reshaping the callout can affect the viewport. Detail callouts also have the following functionality.
Create a detail viewport from an unlinked detail callout.
Link a detail callout to an existing viewport, for annotation purposes.
Sync the callout’s drawing title, drawing number, and sheet number with the linked viewport.
Mode |
Description |
Oval
Creates an oval callout using Box mode; see Creación de óvalos |
Rectangular
Creates a rectangular callout using Corner to Corner mode; see Diseño de rectángulos |
Rounded Rectangular
Creates a rounded rectangular callout using Proportional or Symmetrical mode; see Creación de rectángulos de cantos redondeados |
Polyline
Creates a polyline callout using one of six polyline creation options |
Rounded Rectangle Symmetrical
Click to draw a rounded rectangular callout with symmetrical corners; enter the desired Fillet Radius |
Rounded Rectangle Proportional
Click to draw a rounded rectangular callout with proportional corners |
Polyline creation options |
Select one of six types of control points for the vertices of the polyline; see Trazado de polilíneas. The Fillet Radius value for Arc Vertex Polyline mode is independent of the Fillet Radius value for Symmetrical Rounded Rectangle mode. |
Fillet Radius
Enter the corner radius for a rounded rectangular callout using Symmetrical mode |
Style |
Opens the Resource Selector to select a detail callout for placement; double-click a resource to activate it |
Preferences
Sets the default parameters for the tool |
To insert a detail callout:
Click the tool and mode.
Do one of the following:
Click Style on the Tool bar to select a resource from the Resource Selector.
Click Preferences to open the object properties dialog box and specify the tool’s default parameters.
The parameters can be edited later from the Object Info palette.
Parameter |
Description |
Style |
Replace the current style with one from the Resource Selector, or use the unstyled option |
Hide style parameters |
Hides the parameters that are set by style; these cannot be edited from the properties dialog box or Object Info palette |
Linked Viewport |
Specifies which viewport the callout is linked to. If a viewport is displayed here but it cannot be edited, this marker also defines the viewport (Design Suite required). See Editing detail callouts for details about how to move or reshape the marker without affecting the viewport. If a viewport is displayed and editable, this marker is linked to the viewport but doesn't define it. Unlinked markers display <None>, and a red link icon is displayed next to the marker on the drawing (the icon does not print). If you delete the linked viewport, you can specify whether to delete linked markers or leave the unlinked markers in place. |
Auto-coordinate |
For a callout linked to a viewport, automatically displays the Drawing Title, Drawing Number, and Sheet Number of the viewport in the callout’s marker. If the callout defines a detail viewport (Design Suite required), deselect to enter this information manually. |
Drawing Title/Drawing Number/ Sheet Number |
Identifies the viewport the callout references. If the callout is not linked to a viewport, or if Auto-coordinate is deselected, enter the information manually. Otherwise, the information from the linked viewport is used. |
Note |
Optional text that can be displayed in the marker layout |
Shoulder Length |
The distance from the shoulder point of the leader line to the center of the marker |
Marker Angle |
The angle of the marker; 0 degrees is horizontal |
Marker Position |
The position of the marker and leader line relative to the callout object |
Horizontal Position |
The position of the marker relative to the leader line |
Leader Attributes |
Opens the Leader Attributes dialog box to set the Style, Color, and Thickness of the leader line |
Marker Scale Factor |
Scales the marker larger or smaller by the factor specified |
Click a drawing mode from the Tool bar, and do one of the following:
For a callout in the shape of an oval, rectangle, or rounded rectangle, click to begin the shape, and then click to complete the shape and create the callout.
For a polyline callout, click to begin the polyline, and then click to set each polyline vertex. Click the start point (for a closed polyline) or simply double-click to complete the polyline and create the callout.
Once a callout is in the drawing, you can edit it from the Object Info palette. The following additional options are available when editing detail callouts.
Option |
Description |
Style list options |
Replace: Applies a different style to this object Convert to Unstyled: Allows you to modify the settings and marker layout for this object only Edit Style: Allows you to modify the settings and marker layout for all objects in the drawing that use the current style See Creación de estilos para indicadores y rótulos de dibujo for details. |
Create Detail Viewport (Design Suite required) |
For a marker that is not already linked to a viewport, opens a dialog box to create a detail viewport (see Creación de encuadres con detalle ) |
Navigate to Viewport (Design Suite required) |
For a marker that is linked to a viewport, navigates to the viewport |
Edit Marker Layout (unstyled markers) |
Opens an editing window to change the geometry and text in the marker; see Creación de estilos para indicadores y rótulos de dibujo |
Vertex-based object controls |
You can also adjust the shape or location of the callout object. If there are multiple instances of the detail callout, all instances are updated.
If the marker defines a viewport (Design Suite required), moving or reshaping the marker can affect the viewport. To edit the marker but avoid viewport changes, select Edit > Cut to cut the existing marker, and then select Edit > Paste In Place to paste a new linked marker into the drawing. The new marker doesn't define the viewport, so you can edit the marker as needed.
The Reshape tool has two reshape modes for both oval and rounded rectangular detail callout markers. To reshape an oval marker, click Polyline or Oval mode from the Tool bar. To reshape a rounded rectangular marker, click Polyline or Rounded Rectangle mode. (See Modos de remodelación bidimensional.)
